Author Topic: Other Animations Interfering With Output  (Read 2019 times)
Offline keaneray
« on: May 23, 2013, 01:17:20 pm »
Is it possible to keep different animations (in their own folders) and only output one at a time. I have had problems in the past when other animations interfere with the one I'm outputting for example the duration of the animation I'm rendering is 10sec but the other 'not selected' is 15sec, thus I get an extra static 5sec animation.
Has anyone else experienced this?
  • Guest
Re: Other Animations Interfering With Output
« Reply #1 on: May 23, 2013, 01:32:06 pm »
You would need to set your work area so it ends with the end of the active animation. In the render settings you can tell KeyShot to just render the work area.
Offline keaneray
« Reply #2 on: May 23, 2013, 05:15:55 pm »
Thanks Thomas I'll try that.
