Out of memory (requesting 41 bytes)!!! This may cause instabilities...
Started by Philrider7, May 31, 2013, 05:52:27 AM
Philrider7
Hi, I am importing a 1.2 gb Rhino file into Keyshot, but during the loading I get this message of an error: Out of memory (requesting 41 bytes)!!! This may cause instabilities...
I've watched my memory in the task manager and with 9 gb of memory installed, this crash at 4 gb of memory used. So I dunno what's happening?
Phil
PhilippeV8
I have a couple of gb ram, but can only use 1 due to Windows XP.
Not because you have 9, your OS will let you use up all 9 for a single aplication.
Philrider7
Will update to 4.1 one day when it's up and see if set things right! Thanks Thomas.
William.oliveira
Hi, Thomas!
Same problem appears here when I import some models: "Out of memory (requesting 41 bytes)!!! This may cause instabilities"
I already made the update and it was not resolved. My workstation have 8Gb ram and Windows 7.
How to proceed?
William.oliveira
William.oliveira
I deleted some details of the model and the size down to 15mb. Now, it works.
