blend with color
Started by PhilippeV8, June 26, 2013, 07:56:30 AM
PhilippeV8
Is it normal that if I use "blend with color" to make a texture tone a bit more red or yellow or blue, and I have "global illumination" turned on, the color that "bleeds" on other near objects is the "blend with" color 100%, not the "merge-result color of the texture+blend color".
Do you have an example that you can share?
