Having problem whit textures
Started by mashinacX, July 02, 2013, 11:07:07 AM
mashinacX
I have a problem when I try to add texture, appears to me like the picture that my textures (screen) finds himself on the side (on both sides). Otherwise, the assembly made ​​in SW 2011
If anyone knows what the problem is, thanks in advance.
This looks weird. Is there some geometry that is cutting through the housing?
mashinacX
Yeah, I know. As far as I know, and I worked the calculator, no cutting through the casing but it appears when the texture and cut down on the other side as the pictures.
Try a different projection, like "Y", maybe? Turn off repeat, if it's on, as well.
ah yes - is the recessed surface that has the label the same material as the rest?
mashinacX
Thomas, surface on which the texture of the same material as the rest ... I do not know how to hit command other material for that part of the surface.
You could try a different projection type as Chad suggested, or apply as a label with normal projection. Either one would work.
Or you go back to the modeling software and change the color of the surface, and then reimport.
Hope this helps.
mashinacX
Chad and Thomas tanks for help...Chad, you are right, it's a different position ( now is ''Z'', before ''Y'')
