Diffuse and bump map problems
Started by gustavoahlen, July 05, 2013, 09:26:53 AM
gustavoahlen
Is there some way to change the bump scale without change the diffuse map in the materials? When I change the bump map scale in keyshot 4 it changes the diffuse map scale. I need to modify each map per separate as we can do it on 3ds max or any other 3d software.
Open material settings, click textures tab, then bottom of the screen un-check sync
gustavoahlen
