Author Topic: Material link issues  (Read 8028 times)
Offline kdoan84
« on: July 11, 2013, 01:31:19 am »
Im having issues with material linking in keyshot 4.1, never had this problem in keyshot 4.
I have 2 parts and want each part to have different materials, but no matter how many times choose unlink materials, theyre still link.
Please help, very frustrating.
Thanks,
Kevin
  • Guest
Re: Material link issues
« Reply #1 on: July 11, 2013, 07:07:18 am »
Are the parts on different layers? If not, do they have different colors?
Offline kdoan84
« Reply #2 on: July 11, 2013, 07:23:36 am »
Theyre on the same layer in rhino with different names for material.
The thing is if I import 2 of the same model, one would unlink but the other one wouldnt. Very odd...
  • Guest
« Reply #3 on: July 11, 2013, 07:28:05 am »
Can you share the scene with us so we can take a look? Send directly to me - [email protected] If it is too big to send use keyshot.wetransfer.com.
Thanks.
Offline kdoan84
« Reply #4 on: July 11, 2013, 09:52:48 am »
Another thing I noticed is that when Importing the same file into keyshot 3, then layer's name remain what I've given it in rhino.
In keyshot 4 they become "Default"
as shown:
  • Guest
« Reply #5 on: July 11, 2013, 12:56:53 pm »
Are you using KeyShot 4.1? Also, are you using the plugin or the direct importer? In either case this has been addressed.
Offline kdoan84
« Reply #6 on: July 11, 2013, 05:34:44 pm »
Im using 4.1 direct import.
  • Guest
« Reply #7 on: July 11, 2013, 05:57:22 pm »
In your example all objects must reside on the DEFAULT layer, and are broken out by color. All layer names, order, including sublayers are maintained perfectly in 4.1
Offline kdoan84
« Reply #8 on: July 11, 2013, 08:16:02 pm »
I will give it another try...Thanks
Offline kdoan84
« Reply #9 on: July 24, 2013, 01:53:47 pm »
Hi I'm still having the same material linking issue.
It happen when I import a new model with Retain Materials checked, some parts get linked together with others and won't unlink.
