cheap polycarbonate material needed :-)
Started by tibet, September 13, 2013, 02:51:37 AM
tibet
hi,
wondering, if someone would be kind enough to help me to create this cheap, but still needed material ( polycarbonate ) clear / frost / milky,
i mean a quick tip ( if there is some available) maybe texture, or bump and so on.
thanks!
I know the kind of extrusion you are describing- nasty stuff!  Try using a "water" normal map, and really play around with it to get the common "wavy" distortion effect.  There should be several "water" maps in your texture library.  Then play with a tad of roughness, etc.  At least it may be a starting point, and I'm sure others will chime in as well.
tibet
