Composite ceramic brakes
Started by Tomas, September 23, 2013, 02:22:11 AM
Tomas
The main objective of composite ceramic brakes is to reduce weight, the number of brakes per axle, as well as provide stable friction from very high speeds and all temperatures. A carbon fibre reinforced ceramic process now is used in various forms for automotive.
CCB features:
Are used in high-performance cars;
330 mm diameter, internally vented and cross-drilled;
Stable friction from very high speeds and all temperatures;
The high heat tolerance and mechanical strenght;
35 % weight reduction over iron discs;
Aluminium 6 pistons calipers;
3 control inlets.
Josh3D
Great example and very nicely illustrated. We don't get enough engineering related shots like this. Thanks for sharing!
jhiker
Quote from: josh3d on September 24, 2013, 08:08:47 AM
Amen to that - more real-world engineering would be nice.. :-)
