Cylinder mapped label depth?
Started by JGulliford, September 23, 2013, 10:04:59 AM
JGulliford
Hi, I have a label wrapped around a glass bottle using the cylinder mapping tool, but the label is projected onto the inner surface of the glass.
I'm aware of the 'depth' label property, but this isn't active and is 'greyed out' when in the cylindrical mapping tool, if I switch to another mapping method it becomes active again. Is this a bug or is there another way to get rid of the second label projection?
Many Thanks
Change the color of the inside (or outside) of the bottle before exporting to have separate control over the surface inside.
edwardo
Or.... Create (offset) a surface a fraction of a mm outside the bottle to put the label on. This way you get full control over the material and finish of the label (foil/paper/inked/ embossed etc)
Ed
Quote from: edwardo on September 24, 2013, 07:17:16 AM
Ed
Oh yes, the good ol' offset surface trick... nice!  :D
