IZ-350 Motorcycle from WWII
Started by TpwUK, September 30, 2013, 07:26:02 AM
I rendered these pictures just over a month ago for the modellers of the motorbike. You can see the full range of renders here ...
https://grabcad.com/library/iz-350-high-resolution-renders-1
The model can be found and downloaded for free from here ...
https://grabcad.com/library/iz-350-dkw-350-update-6-1
Renders were done with KS4.1 :)
Josh3D
Love the paint scheme on the first one, but feel the image could be pushed a tad further. Rougher tires and slightly rougher paint in general. It may be that the backplate seems off from the model.
Thanks for suggestions Josh. I struggled with the tyre texture and it does show, but ran out of trial licence time so couldn't spend any further time on it :(
The paint work has orange peel added and looks pretty cool on close-up. The backing on the first shot is the standard one in Keyshot's HDRI libraries and i't a pain in the backside too trying to camera match it so I just settled for blurring it heavily with DOF :)
thomasteger
I don't know if it's just my computer/gfx card but the backplates in KS all seem to be 4:3 rather than 16:9 and even though you can disable resizing in prefs, it just don't seem to work here and i end up with a 4:3 ratio render on a 16:9 display with massive black margins on either side, even if i use huge images {(non keyshot ones) i still get the same problems, so i tend to settle for studio shots. Then I have waaaaaaay to much fun rendering that i forget to go back to these problem renders and run out of time :P
