Import missed some parts
Started by PaulP, November 22, 2013, 02:08:50 PM
PaulP
I'm using Keyshot 3. I built a assy. in Inventor, it has some files that I downloaded form a manuafacture, specifically a 5" swivel caster.
When I  import it the casters don't come with it. Other files I downloaded from the same manufacture do work.
Any idea of what to try to get the whole thing to import?
Thanks,
Paul
PaulP
would this be better in a diff section of the forum?
thanks,
Paul
thomasteger
You can export to CATIA from Inventor and then import. In KeyShot 4, the Inventor import has improved significantly.
PaulP
...if I had Catia! Thanks anyway though.
#4
Quote from: PaulP on November 24, 2013, 10:00:16 AM
You're unable to export as a Catia file type from Inventor? Well, then try STEP, IGES, etc...
thomasteger
You don't need CATIA. The export to CATIA should be a standard export function in Inventor, not unless I am mistaken.
PaulP
OK, I never tried that, thanks I will see what I can do.
Paul
