Render preview/progress not showing
Started by ChrisV, August 06, 2010, 12:57:46 PM
ChrisV
Since upgrading to KeyShot 2, I'm not able to see the output while it's rendering.  I don't see the "spiraling squares" as in v1.9.  The window is black and all I can see the progress info at the top.  The rendering finishes and the file is saved without a problem, but it would be very helpful to be able to check it as it's going.
The preview/live window works fine.  Resizing the render window doesn't help.
Running on Win7x64.
KeyShot
Does this happen at all resolutions? The rendering window still shows the spiraling squares, and you are the first one to report them as missing?
-- Henrik
ChrisV
Hi Henrik,
I have tried low and high resolutions and it's the same for all of them.  I uninstalled and then reinstalled, but again nothing.  Normally I use SpaceClaim to create the models, but the same thing happens when loading one of the KeyShot models.
Any thoughts on what might fix it?
Thanks,
Chris
KeyShot
Can you send a screenshot of what happens to support@luxion.com then we can take a look at it?
Thanks,
Henrik
ChrisV
Hi Henrik,
I have found a solution to the problem -- by disabling 'Enable Desktop Composition' under
Control Panel > All Control Panel Items > Performance Information and Tools > Adjust Visual Effects
Switching from 32-bit to 16-bit display had the same effect.  It could be the transparency of the window borders in the Aero interface.
I'll send the screen shots.
Chris
