Keyshot animation stopped working
Started by BrentShanahan, December 13, 2013, 09:31:02 AM
BrentShanahan
I had an animation of a simple camera orbit around an object. I was trying to render it in keyshot VR from the render panel but every time I hit render it would  re-orient the camera and move the model to the center of the screen. I tried a bunch of times to get it to render from the location the camera was set at but it refused to.
I went into the animation editor to check that the animation would work from the location that I had put the camera, and when I hit play it refused to work! I tried adding a new camera to orbit, and when I added the animation, it is set to start at 0 and the end time is stuck at 0, yet the duration is 5 seconds. No matter what type of animation I try to add it does the same thing and refuses to allow me to animate it!
I tried closing and re-opening the program but that didn't help. I'm not sure what to do because I really need an animated VR render of this object!
Is there a way to un-do whatever I did when I was trying to get the VR render to work?
BrentShanahan
I just tested it on my co-workers computer with no luck.
Then when I moved it back to my computer it worked again. wtf
I'm not sure what happened but I'm glad to have it working again.
