Author Topic: Update functionality of Network Rendering doesn't work  (Read 3081 times)
Offline DonChunior
  • Full Member
    • BOINC - Donate computing power instead of money
« on: January 01, 2014, 10:37:49 pm »
We use Network Rendering version 4.3.4 from 17th of December 2013.
When I choose Check for updates from the help menu of the network queue, I always get following error: Master Critical Error - Could not connect to the update server, please try again later
Internet access is available at the Master.
Offline Claus Jensen
  • Administrator
  • Full Member
Re: Update functionality of Network Rendering doesn't work
« Reply #1 on: January 02, 2014, 06:04:07 am »
Are you connecting through a proxy server?
/Claus
Offline DonChunior
  • Full Member
« Reply #2 on: January 02, 2014, 06:10:55 am »
Yes, we're connecting through a proxy server.
The configuration in the KeyShot Network Configurator is set to "Automatic proxy detection".
Offline Brandon Davis
  • Jr. Member
    • KeyShot
« Reply #3 on: January 02, 2014, 12:30:21 pm »
Can you try manually setting a proxy connection? Simply select the type of connection(HTTP/SOCKS) and give the IP address and port number of the proxy server. Click "Close and restart services" when finished.
Offline DonChunior
  • Full Member
« Reply #4 on: February 10, 2014, 09:49:27 pm »
Hi Brandon,
meanwhile I added the settings of our HTTP proxy server, but I still get the error message!  :(
The only thing that has changed is, that the error message appears immediately. Before I set the proxy settings, it took some 10 seconds, till the message showed up.
Our network guru means, if you could tell me the IP address of the update server, it can be added in a "white list" at our central IT department. Hopefully it then works!
Can you please tell me the IP address of the update server?
Best regards, DonChunior
PS: The password of the proxy configuration gets saved as clear text! Please change this, that's not state of the art.
« Last Edit: February 10, 2014, 10:02:01 pm by DonChunior »
Offline DonChunior
  • Full Member
« Reply #5 on: March 20, 2014, 01:08:29 am »
Because of our complicated IT infrastructure (several firewalls, proxy servers ...) for us it is still not possible to use the auto update functionality.  :(
Can you provide another way to get the latest updates? This means, that I don't want to send an email to the support every time, to ask, if we've got the latest version.
