Plugin Installation on ProE Stations without Keyshot installed
Started by gpeter73, January 14, 2014, 08:23:07 AM
gpeter73
just a quick question. Is it possible to install the Keyshot Plugin for ProE on Workstations where no Keyshot is installed?
A customer won't try to install before he know it works.
thomasteger
Yes - you can do this as long as Pro/E is installed. You basically get an exporter, allowing you to export the geometry to a KeyShot file which can then be opened on a machine that has KeyShot installed.
