livelink to spaceclaim: to make it possible to bring any filetype to keyshot
Started by mafrieger, February 08, 2014, 07:10:08 AM
mafrieger
Keyshot is an really great an easy to use programm with lots of advanced possibilities
Spaceclaim is the same for CAD plus having advanced import possibilities.
- so the perfect combination would be spaceclaim + keyshot.
Having this you could import nearly every filetype from any cad program via spacelaim's advanced import possibilities,
optimize/modify the file and than pass it to keyshot.
At this time it's not that great because you have to do often lots of work twice within keyshot - because their is no livelinking and changing a small part of the geometry in spaceclaim you have to do all the work again in keyshot... :'(
=> livelinking keyshot to spaceclaim and you could get the most out of keyshot  :)
=> what do you think?
@ keyshot team - can we have any hope that this would happen??
mafrieger
yes I know that there is already some integration as you can see here:
http://youtu.be/SeCxKU09n74
- but its no real linking
Modifying a small part of the geometry in spaceclaim after having rendered with keyshot, you have to setup everything again...
thomasteger
All the plugin work is done by SpaceClaim. LiveLinking will be available with SP1 of the current version.
mafrieger
mafrieger
just updated to SC 2014 SP1.
Keyshot is also latest version.
Not working out of the box. Same behaviour than before :-(
Any idea where and how to configure it?
thomasteger
According to SpaceClaim it will now be in SP2. For all questions regarding the plugin please contact SpaceClaim support directly.
mafrieger
many thanks for this information!
result => :(
hopefully SP2 will arrive before autumn...
mafrieger
KeyShot
It is in the SP2 service pack for SpaceClaim coming later this month as far as I know.
mafrieger
Thanks for your answer!
So just a small delay...
Do you know anything about general KS 5.0 compatibility?
and will it be possible to directly live-link the model in NURBS quality?
If so this is a step from 0 -1000miles/h in the workflow+quality  ;D
KeyShot
It should work with KeyShot 5. I don't think it will support NURBS initially.
mafrieger
You were right: Spaceclaim 2014 SP2 is available today  :)
A little bit confusing:
there seem to be a FREE-Version of Keyshot included in this Service Pack of Spaceclaim  :o
see https://www.youtube.com/watch?v=Un2cmKFk4Hc
BUT
- there is no word spread about livelinking - do you know anything?
- what is about existing customers of Spaceclaim and Keyshot? do they have a benefit too ?
- what are the differences between Full Keyshot and this free included version?
mafrieger
so we tested it today and updated our keyshot-pro to v5 and spaceclaim to 2014 SP2
the good news:
you can use Spaceclaim still together with your full version of keyshot  :)
the sad news:
Livelinking seems not be possible/available as far I could see:
every time you change something in spaceclaim you have to resend/reopen it in keyshot and it starts as a new part and the changes you have made in keyshot have to be redone  :(
I also looked into the settings of both programs and could not anything to resolve this.
the rendering nurbs option is also greyed out in the menu....
hmm hopefully I didn't get it right and there is a special trick to activate livelinking or another way of better integration??
UPDATE:
just found your Blog Post about Keyshot & Spaceclaim
https://www.keyshot.com/spaceclaim/
=> GREAT NEWS: Livelinking should work!!!
"LiveLinking
As soon KeyShot is started from SpaceClaim through the Render option, the two applications are linked. You may assign materials or set up lighting and camera angles inside KeyShot. In SpaceClaim, you may continue to refine your model. When you are satisfied with the changes, select Update from the SpaceClaim menu."
but what to do to make it work?
Do one need a special version of Keyshot?
Or is the mentioned "update button" hidden somewhere?
every time clicking the Keyshot button in Spaceclaim a new instance of Keyshot is opened...
mafrieger
just installed the latest Keyshot 5 update version 5.0.98 from 07/07/2014.
Still the same...
any ideas or a small description / example to show how livelinking beteween keyshot and spaceclaim should work?
Many thanks!
