Keyshot Crash when adding multiple animations to a folder
Started by red_orca, February 10, 2014, 09:26:50 PM
red_orca
If I try to add 4 or 5 animations to a folder - Keyshot will crash.
Every. Time.
I can make a folder of less than that and then add each animation to the folder...but that's not an ideal workflow...
Just tested it real quick with 5 animations and it worked. What version of KeyShot are you using exactly (under Help>About)? Also, so we are on the same page, what OS are you using as well?
red_orca
I'm on 4.3.10
OS is Windows 7 Professional Service Pack 1
Running on a PC using an Core i7 @ 3.46GHz with 12GB RAM
Have got Keyshot set to using 11 of 12 cores.
Geometry was created in Solidworks 2012
I also have a Ground Plane and a few keyshot standard cubes in the scene.
In the scene tree I've made 1 new group of few of the imported parts
I also have an animated camera.
.BIP filesize is a touch over 45MB
The crash occurs when I make an animation folder with both camera animations and geometry animations (but am only grouping camera with camera and geometry with geometry)
I have a total of 19 animation events in my timeline. This problem was occurring when I had less that though.
