Can someone explain
Started by EGON, February 24, 2014, 01:45:03 PM
EGON
"If you are running KeyShot Pro, you can use the KeyShot HDR Editor which allows you to set a highlight by clicking onto the model." I can't get it to work.
edwardo
start the editor...
Right click anywhere on the backdrop (not a model part)...
choose 'set highlight'...
now holding 'cmd' key click anywhere on the model you want a highlight...
voila
edwardo
also... make sure your HDR editor is checked and active inside the preferences/plugins panel
EGON
Thank you so much Ed. I was going nuts trying to figure it out.
edwardo
no problem, was just fudging about with the HDR editor myself when i saw your post
thomasteger
This is not how it works now. You open the editor, go to pins and then click on "set highlight" or click on the "+" button with the arrow.
