Transition between camera vies
Started by nhnk01@gmail.com, February 25, 2014, 10:17:44 PM
nhnk01@gmail.com
Keyshot really needs to introduce the transition between different pre set camera views.
This was already mentioned and on the keyshot to do list back in february 2013... so where is it?
KeyShot
Winch Doctor
+1 for this. I assume you're talking about an animated transition between views, which would be amazing. If this isn't what you meant, I'm sorry. Our intern from Germany is using Keyshot 5 and as far as we know, this function is not available. It would be under the animation wizard, correct?
Rex
New in KeyShot 5 are "Camera Switch Events". These allow you to switch cameras/viewsets during an animation. In order to use this feature you must have 2 or more saved cameras/viewsets. Select the camera you wish to start with in the scene tree>right click and you will see "Camera Switch Event" and a flyout to select the camera you want to switch to.
