Looks
Started by EGON, March 09, 2014, 05:11:07 PM
EGON
Kinda like a space age marker comp using KS +PS for look & feel.
PhilippeV8
perspective is a bit off in the first one  ;) :-X ;)
stunning otherwise tho !
SergioBL
Last image is awesome!!
EGON
Thanks! So how would you fix it Phillippe ? Twist?
PhilippeV8
I would turn on the ground grid .. that might help .. I think it just needs a small increase in the perspective slider.  Not sure if after that you need to twist a bit or not.
From what I read, with KS5 all this should be a lot more simple from the start with the "match perspective to backplate" option  :D
I'm curious to see how that will work ... should be good if it's a little like the sketchup option.
feher
Do you sleep ! These all look good. Love the Drama and color pallets.
Thanks for sharing.
Tim
