Typing in negative values does nothing
Started by mikalind, March 09, 2014, 10:13:31 PM
mikalind
Hahaha, yes i have.
And if i do the same thing as i said, with danish or US settings, it works just fine.
In fact, most of the instances in Keyshot where i affect settings with manually typing in negative values, this issue shows up.
And its a bit hard to get exact camera settings when i have to use the sliders.
M
mikalind
Even if i cut&paste a negative value that worked when using the sliders, the camera does not react.
M
Morten Kristensen
Extremely weird indeed. Unfortunately, none of us here can reproduce it in any fashion.
I will create an issue in our bug tracker and then we'll follow up on it.
Hope you can manage.
Thanks and have a good day.
mikalind
Hi again
I have installed Parallels Desktop and i run a demo version of Keyshot 4.3.18 there on windows 8.
No issue there.
Mikael
peterfagerberg
I have the exact same problem - Keyshot 4 doesn't accept negative values from the keyboard. And just like mikalind I have a Swedish setup:
Mac OS X 10.9.2
Region: Sweden
Language: Sweden
Keyshot just seems to ignore typed negative values. I always been able to work around it by using the sliders and mouse positioning but now I've run into a wall with a camera movement.
It's troublesome that you don't seem to be able to reproduce this bug because it REALLY needs a fix! Please let me know if there is anything I can do to help.
Best regards ///Peter
peterfagerberg
Well, I found a quick workaround using the mouse scroll wheel. It's a bit iffy but seems to work in a pinch.
Position the cursor marker in the field (exactly!) and scroll up or down. This should change the number and you're able to reach negative values. However, if it's a big number you'll have to do A LOT of scrolling!  ;)
Rgds///Peter
