Cheap Headphones TDK
Started by crazybird, March 13, 2014, 05:39:17 PM
crazybird
Because model and render a DR Beat is too mainstream... my headphones TDK (8 pounds in ama*on)
I hope you like the renders. I've used basic materials in most of it because this ones are very similar to the originals. But I have had some problems with the stickers, I used png photos, which had the background deleted but appears a rectangle with the TDK logo anyway... I couldn't solve that...
Thank you and constructive critics please.
thomasteger
I like the simplicity of the model, and the cleanliness of your renderings. Well done.
m2tts
I can't see your images for some reason.
I had your png problem the other day and it was because I had saved the png as a grayscale image. Go into PhotoShop and change the image type to RGB; then the transparency will show.
Josh3D
Yes, really clean design. I love the way the Black pops on the plastic outer of the earpiece. The edges of the decal are showing slightly though in some spots.
crazybird
thank you m2tts I going to try that of the RGB.
And josh3d, I 'm watching the last webinar and learning a lot about the materials. Very interesting stuff.
alp
