Author Topic: Light through glass and liquid  (Read 17997 times)
Offline Rydi
« on: March 18, 2014, 06:50:05 am »
Hello everybody
Do you know what is the best way to achieve light reflections on the ground like that ?
I tried to add a sphere on the scene and then apply a light as material, with all options checked on the rendering pannel but my result was very grainy... not smooth at all, I can't give you a preview now but i'll do. Before that, anyone have a Idea ?
The result is very very smooth, I think the material ground matter, as well as the lighting.
Thank you guys !
Offline Rydi
Re: Light through glass and liquid
« Reply #1 on: March 24, 2014, 07:50:34 am »
Hi guys,
I hope with a screen you will see what I am talking about, look in the picture all the dots of light, i want something smooth, but even with my ground with 128 samples, my caustics at 10, the quality shadows to 5, i have this result ...
Any idea ? I use a HDRI environnement black with just one spot of light.
On the left this is a screenshot of keyshot, on the right the final render.
Thank you !
Offline Rydi
« Reply #2 on: March 24, 2014, 12:00:43 pm »
I really don't like to reply to my own topic and create multi post but if someone have an idea I will really appreciate :)
Offline richardfunnell
« Reply #3 on: March 24, 2014, 12:32:22 pm »
Hi Rydi,
Can you share this scene with us?
Offline Rydi
« Reply #4 on: March 25, 2014, 11:35:32 am »
Hi Richardfunnell,
Here is the scene, if you achieve something that will be GREAT :)
Offline Rydi
« Reply #5 on: March 27, 2014, 03:37:03 am »
Hello here :)
Maybe this is not possible ?
I don't think so but if no one can answer maybe it is :s
Offline KeyShot
« Reply #6 on: March 27, 2014, 12:32:03 pm »
I recommend you try using the realtime renderer for this type of scene with a detailed caustic. You can use the max samples approach, which will render the scene as long as you use enough samples.
Offline Rydi
« Reply #7 on: March 28, 2014, 01:33:08 am »
Okay thanks for the tip ! I keep it ;)
Offline DriesV
  • Administrator
  • Total likes: 49
« Reply #8 on: March 28, 2014, 05:37:56 am »
I gave this scene a shot today.
I did one of my usual tricks of doing separate passes for general lighting and caustics.
The reasoning behind this:
* Point lights generate the sharpest/fastest caustics, but are not suitable for general lighting of your product.
* HDRIs with multiple 'light pins' (which is probably what you want for HQ jewelry/fashion ware) cause caustics to take a long time to converge.
Attached is the result after compositing in Photoshop.
Here you can download a zip containing:
* KeyShot packages with scene files for both the base and caustics pass
* EXR renders out of KeyShot (base & caustics)
* Photoshop working doc
* Final image
I did this really quickly.
You can get better results with some more tweaking in KeyShot, more render time and better compositing.
I hope this is what you're looking for... :)
At least I had a lot of fun taking your scene for a spin! ;D
« Last Edit: March 04, 2019, 03:50:36 am by DriesV »
Offline DriesV
  • Administrator
  • Total likes: 49
« Reply #9 on: March 28, 2014, 05:56:16 am »
Btw,
I'm not usually the guy to self-promote, but recently I hosted a KeyShot webinar where I covered the process of rendering and compositing this way:
https://www.youtube.com/watch?v=IY626fh_Xcs&feature=youtu.be
The section about caustics starts at around 54:00.
Offline edwardo
« Reply #10 on: March 28, 2014, 06:03:37 am »
Those caustics are amazing Dries. Can you let me know (roughly) how long each render took and the spec of the machine you rendered it on?
The reason I ask is that Im having speed issues getting to this level of quality. I'm playing about with caustics for the first time (I'v got V3 but playing with V5 beta at the moment). I will open these .bips and take a look at your settings and see if its feasible to render on my laptop (mbp 2014 2.6quadcore i7, 16gig ram)
@Rydi... Good luck with getting your scene the way you want it - I hope Dries setup points the way.
Edwardo
Offline DriesV
  • Administrator
  • Total likes: 49
« Reply #11 on: March 28, 2014, 06:11:07 am »
Ed,
This was rendered on a i7 3930K machine (88fps in camera.bip on KS4.3).
The caustics pass (2500*1250) rendered for 45 minutes. (You can probably get faster results with advanced control rendering...)
The base pass rendered for less than 10 minutes, I think.
Offline DriesV
  • Administrator
  • Total likes: 49
« Reply #12 on: March 28, 2014, 06:23:55 am »
As for rendering with advanced control: the caustics quality can be increased by dialing in a value of up to 100.
Offline edwardo
« Reply #13 on: March 28, 2014, 06:36:01 am »
thanks Dries
Offline Rydi
« Reply #14 on: March 28, 2014, 08:05:06 am »
Dries i'm gonna look your file soon because i can't right now, but when i'm watching your result I just want to call you God.
So thank you, a lot :)
