Author Topic: adding more than one turnable to an animation?  (Read 2341 times)
Offline hugo
« on: March 26, 2014, 12:50:39 pm »
If I do a default 5 sec. turntable animation with saved frames.
How can I add 2 or 3 more turntables to lengthen my animation?
I would presume I should be able to use the original 360 degree turntable sequence of frames 2 or 3 more times?
Offline DriesV
  • Administrator
  • Total likes: 36
Re: adding more than one turnable to an animation?
« Reply #1 on: March 26, 2014, 01:22:01 pm »
Do you have AfterEffects?
F.i. in AfterEffects, when you import an image sequence, you can set that footage to loop any number of times you want. You can set the number of loops through 'Interpret footage' > 'Main' (where you specify frame rate as well...).
Offline hugo
« Reply #2 on: March 28, 2014, 10:04:11 am »
No I don't.  I first thought I was missing this option in KS.
Actually Windows Live Movie Maker does the same basic job, but saves to .wmv only.
but also publishes to You tube, which converts it to .avi.
