changing KS opening RES: ?
Started by hugo, March 31, 2014, 07:48:00 AM
hugo
The KS opening Res: in my heads up display appears to have changed to 884 x 663, How to I change the Res: ?
TIA!
thomasteger
hugo
So you have to import an object, before you have access to the settings menu
No, not at all - When you select import you get a dialog, click the show settings there, and then you can set the advanced import parameters :)
