Delete render layer from dropdown list?
Started by Pepster3D, April 01, 2014, 01:25:21 PM
Pepster3D
I deleted some objects from my scene file and want to delete the old render layers from the drop down list as well (so I don't get black render layer passes when I render).  How do I delete the layers even if they're empty?
thomasteger
#1
They should just be be removed automagically once they are empty.
thomasteger
#2
Yes - once you select another layer the empty layer will be removed.
Pepster3D
OK, I see that the render layer went away when I deleted the objects.  But what if I want to hide a few layers (don't want to delete)?  I'm still stuck with blank render layers rendering.
Pepster3D
*bump*
Any solution for hidden layers and getting rid of their render layers?  Still getting black jpgs after hiding some objects.
thomasteger
Pepster3D
