New member running AMD FX 6300
Started by joseph, April 02, 2014, 07:37:56 PM
joseph
Asrock 970 Extreme3 R2.0
AMD FX 6300 running at 3.77 GHZ
16 GB RAM SuperTalent DDR3 1600 4GBx4 at 208x
HIS i-Cooler HD7700 1 GB
WINDOWS HOME PREMIUM 64 BIT
KeyShot 4 for IronCAD 4.3.18
89.7 FPS peak / 35.5 FPS
58.1 FPS /  71.8 FPS on performance mode
Render time:  800 x 554 99MB 6 cores 16.6 sec.
Regards
jiyang1018
Cannot find an AMD processor called FX3900.
joseph
I made a mistake it should be a FX6300. I have updated my PC with a FX6350 at standard multiplier of 19.5x - 21.5x for turbo mode, Kingston Hyper Fury DDR3 1866 8GB x 2 clocked at DDR3 1600 with bus set to 214 running 1711.8. The net cpu speed range now is 4.173 GHZ for all cores and turbo a half of the cores to 4.60 GHZ. Also replaced the GPU to a Sapphire R7 260X 2 GB video card. Don't have an idea what matters most or the real fps figure. If I change the view point opposite current horizontal position the FPS is higher at a constant rate
