zbr fibermesh to keyshot?
Started by darkarts, May 08, 2014, 04:30:14 PM
darkarts
Hello, how can i export zbrush fibermesh to keyshot? 8)
djorzgul
OBJ or you export curves to maya, make geometry out of them and export to keyshot.
First solution is quicker... Second one more adjustable...
ScaredOfSalad
In order to convert fibermesh into polys that can be rendered in Keyshot, you need to apply a texture map to the fibers first, then export as an OBJ. If you have polypainted your fibers, make sure the polypaint is converted to a texture map and exported so you can apply that map in Keyshot. It should all import with no issues once you do that.
