Render just shadow with model invisible
Started by keaneray, May 13, 2014, 12:18:24 PM
keaneray
Hi guys,
Is it possible to just render the complete shadow with the model invisible? Below will show what I'm trying to achieve.
Cheers,
Ray
richardfunnell
Yes, this is possible. Link all the materials in your model and set them to the emissive material type. Uncheck "Visible to Camera" and "Visible to Reflections" and make sure Global Illumination is turned off in your realtime settings. I also added a ground plane to improve my ground shadow quality.
You can see the desired effect in the attached images  :)
keaneray
DMerz III
And pull it as a TIFF, with Alpha checked. Then you can easily duplicate the shadow layer as many times as needed to "darken" it.
