gradation across multiple objects
Started by Pepster3D, May 22, 2014, 01:58:39 PM
Pepster3D
I've attached a sample image to show you what I'm looking to accomplish in Keyshot.
Is there a way to apply a gradation texture onto multiple shapes, as if they were 1 shape?  In other words if I have 50 circles in a grid pattern, can I apply a gradation to them as a whole instead of 50 separate gradation?  So the gradation will go from the right of the screen to the left covering all circles as if they were 1 object?
edwardo
Just make sure all the surfaces are grouped/the same colour/in the same layer when you export them from your CAD package of choice.
thomasteger
Sorry for the delayed response, Darlene. Took a break from racing to answer your post - LOL.
You can simply a material at the top level of the model in the scene tree, or copy and paste with link (shift left click / shift right click) any material that you applied to one of the squares. Then you can treat the objects as one single object.
I hope this helps.
Pepster3D
Thank you Edwardo and Thomas!  I'll give it a whirl. :-*
Pepster3D
Hi-OK, it's not working for me.  I've attached a screen capture of my scene.  A group of squares with the same material ID but the texture is treated separately by each square even though they are in the same group.
thomasteger
You imported this as a single file I assume?
Pepster3D
Yes-I made the squares in 3DS Max and grouped them.  Exported them via the Keyshot plugin as a bip.  All 1 file.
thomasteger
Pepster3D
Sure, here's a file. I tried grouping the squares a few different ways, but still can't get 1 gradation across all shapes.
thomasteger
Thanks. Can you send the original CAD file so we can look at that too?
Pepster3D
The original file is in 3DS Max.  Do you want a max file or do you want 3ds or obj?
thomasteger
The Max file please. We have it here.
Pepster3D
Here's a max file...
Rex
This appears to be a bug with the 3ds bip exporter. If I export as obj it works fine.
Pepster3D
Weird.  OK I'll try obj.  Thanks T
