KS 5 PRO slight bug
Started by dunk, June 11, 2014, 09:50:22 AM
dunk
Hi All,
Using KS 5 pro and coming up against a slight problem with applying axalta materials in which half way through working with a model (somewhat medium size poly count) it suddenly reverts back quite a few stages when i next apply a material. Undo does not help this. Anybody got any ideas? cheers
Rex
Hey dunk,
So what your saying is, when your applying materials to your scene and you drop an axalta material onto a part, the scene will change materials back to a previous state? Can you reproduce the issue reliably?
Rex
dunk
Yes that's correct. In terms of replicating it i would say that it has happened 4 times, with the same model and with axalta. I am working on one model at the moment so i cant say it happens across the board, i can have a play and see if i can replicate it easy enough.From the top of my head i think its when i have applied axalta to a number of items, gone to apply a different material, then gone to apply axalta again and it reverts back to the start of my first bunch of axalta applications (hope that makes sence). do you want me to try and replicate it.
Rex
You can send the scene to rex@luxion.com via keyshot.wetransfer.com and I will take a look and try to reproduce. Thanks
