keyshot vr help with setting
Started by syfer, June 19, 2014, 05:08:52 AM
syfer
Hi ok I need some help when I render out vr its way to to big and takes for ever to load on my website I set Horizontal frames is set to 16 and the vertical frames are set 16 also with image quality set to 100.
Know I am new to this vr thing can can help me out I need these to load fast on my web host can any one help or recommend the best setting for vr?
With the image size to 720 screen for pc.
I have tested this on my phone and oh my god not even on mobile website it looks so bad to big this vr is not made for phones at all.
link
http://umarabid.com/test565/
htc evo 3d not working as the screen of my phone is way to small so i don't know how you can advertise this as mobile ready more like tablet ready only.
the code i used was this
<iframe src="http://myhtmlfilepath" width="100%" height="700px" frameborder=0 marginwidth="10px"></iframe>
which if you go to on your phone it looks to big grr.
In the advanced rendering setting I have ticked
scale down with brower width
add down scale gui button
I am using WordPress.
Rex
Hey syfer,
16 x 16 means your browser has to load 256 images! If you want it to load faster just use less frames. I also recommend for the best results keep your vertical and horizontal angle increments at an equal value. Try 9 horizontal frames and 5 vertical so the increments are both 40 degrees and you only have a total of 45 frames to load.
Rex
syfer
ok thanks can I ask is this code ok
on my tablet its a bit big I have samsung tab 2 a small tablet i think on ipad it will look ok.
is this code above ok?
I think on my website it looks a bit big and need advise.
syfer
I might even use this third party plugin like
Smart Product Viewer from codecanyon
http://codecanyon.net/item/smart-product-viewer/6277697
seeing that will work.
Use keyshot vr to make the turntable like animation then import that in Smart Product Viewer is the best way to bad that keyshot vr does not do what Smart Product Viewer can do but their is allways an way around that  :)
