interior bedroom
Started by cx66, June 30, 2014, 08:52:03 AM
cx66
sketchup 2014+ks5
feher
Looking good. Did you model this ? I would like to see you push this more. Add some drama to the shot. Make me feel the textures and materials in the room. What do you want me to look at first...etc Take it to the next level you'll be happy you did.
Thanks for sharing
Tim
rodesk
very good, correct the carpet texture.
lack some light through the window in my opinion
cx66
thank you, I have the same problem in every render​​, I can not give a good texture for the carpet to simulate the fibers, if someone knows how, please explain
rodesk
#4
 correct size scale uv . or Create fur in Maya
as you put the image behind the window?
cx66
Quote from: feher on July 02, 2014, 04:11:46 PM
Thanks for sharing
Tim
thanks tim, I understand what you say, and when I see your work I am away, but I think the more you work the more you improve
xavier
cx66
Quote from: rodesk on July 02, 2014, 09:19:12 PM
I see, but I do not control maya, I tried to do in sketchup with "make fur", the result is very random
rodesk
understand, then add a better texture and corrects the scale
I would like to see in KeyShot scena from which to see the light :)
And behind that image agregates glass not do that
cx66
#8
Quote from: rodesk on July 02, 2014, 09:30:42 PM
for the light, I used one hdr, and 3 area lights, in front of the bed and sides.
for the carpet I tried to change the scale, but I can not seem to give the volume, if you have an example
rodesk
then no light enters through the window?
cx66
#10
of course, there is the clearest reflection at the ground in front of the window, and there 2 windows in the scene
rodesk
great, I can not even alcansar good lighting inside. I hope to see more render your model
Despot
