Keyshot enquiries on glass surface
Started by janewang123, July 06, 2014, 08:06:46 PM
janewang123
Hi
I'd applied glass material to my model however I keep getting uneven lines and waves on the glass surface. Is there anyway I can make it straight or improve the quality of it?
Thanks! :)
blanaba
I'm new to keyshot but this looks like flawed geometry. Can you post the wireframe view of the area?
janewang123
This is the wireframe view of the object! :)
The Topology is not good, is this an OBJ or other wire mesh from a NURBs modelling app. It looks as if you have created a solid which is good. But then if you look at the wires where they join horizontal and vertical there are some edges that are very close together. They need thinning out a little, unless of course you are using version 5 of KeyShot, KS5 supports rendering of NURBs surfaces now.
janewang123
Alright will look into it. Thanks so much! :)
