Edit>add geometry: where (which folder) is geometry stored (win 7)?
Started by jupille, September 11, 2014, 09:48:02 AM
jupille
Want to use the edit> add geometry function to add primatives (KS5) but the only thing that comes up is ground plane. Where are the other primatives saved and how do I get to them?
Thanks in advance.
Rob Woods
I'm having the same problem.  When I first installed the upgrade, the 'add geometry' function worked, but for some reason the only option I have now is to add a ground plane.  I've not changed any settings or preferences.
Help please?
Rob
thomasteger
The Geometry that can be added is stored in your resources folder under KeyShot 5/Models. Any bip file that gets added to this folder will be available through the pull-down menu.
