Cant make keyshot to load HDR light Studio plugin
Started by onizukadesuka, October 28, 2014, 01:35:33 AM
onizukadesuka
Hi there,
I am having issue using HDR light studio 4 with keyshot. Its seems there is not interaction between those too. In the preference menu HDR light plugin is stated as unloaded.
Did you encounter this problem before.
Thanks for future help
As far as I am aware this is OS x specific, so if you are using an Apple Mac system then it won't link with the plugin. You can however use the light studio to create your HDRi's, just keep saving adjustments to the same file, then use the reload button on the environment tab.
onizukadesuka
Thanks for the tips, I will try this while finding a solution. I am not using os x but window 8 on a wacom companion.
