One label across different instances on same Planar
Started by pupdogg, November 13, 2014, 12:46:05 PM
pupdogg
Please see image_2.jpg, it has one (1) object with multiple instances...full view can be seen in image_1.jpg. I am trying to place the "red" label (which will actually be one [1] image) across the top plane of all of the instances of this object...how can I do this? The end result should be that all instances have one (1) image showing from the top-left instance to the bottom-right. Please help.
Rex
pupdogg,
To be clear, are you asking for a separate copy of the label to be instanced on each model. or a single label mapped across all models?
Rex
pupdogg
#2
Hi Rex,
Single label mapped across all models please. Similar to your image titled single_label.jpg but with a slight difference, the label should not wrap around on each model. It should show across just the top face of all models or instances of a model. Thx
Rex
Here is how I did it with SolidWorks:
- Create cube in SolidWorks "Part" mode
- Assign color to top face of cube so label does not wrap
- Create linear pattern
- Send to Keyshot to appy texture/label using planar Y mapping type
Let me know if you are still having trouble.
Rex
pupdogg
I can't get 1 label to span across all cubes...I'm on version 5.1.57.
pupdogg
#5
Really weird...I can achieve the results with a 2x2 cube matrix but not 32x32...see attached...also, when I pattern the 2x2 model, each instance maintains it's own label even though I spread it across the Y planar? how can I get the label to apply across all patterned instances?
Rex
What CAD application are you using? Did you follow the steps I described?
