Newby from the Netherlands with two questions.
Started by Highlander, December 08, 2014, 09:42:48 PM
Highlander
First of all, greetings form the Netherlands ;) Qustion 1. Is there a possibility to work and render at the same time in keyshot, because if keyshot is rendering i can't do anything in keyshot. 2. Are there measurement settings or ruler where i can get measurements info from??
Greetings Highlander
thomasteger
@1. You can do this if you have KeyShot Pro. The option is called "render in background".
@2. No, there is no ruler. If you need to place object at a certain distance from one each other, turn on the ground grid. The grid represents the units you are working in.
Highlander
