Render Layers
Started by Justin M, December 20, 2014, 01:21:16 PM
Justin M
Is it possible to just render out the render layers and not have to render out everything again?
Also, is there a way to save out the render layers into the same format as the main render? I have .tiffs at 32bit being saved out, the render layers are on .png - 8bit.  Also, when will 16 bit .pngs be available for render format option?
Rex
Hi fantomas81,
Render layers can only be outputted as .PNG. Render layers cannot be outputted without the full image; however, you can use region render to frame the desired area.
Regards,
Rex
