Keyshot for zBrush. Cloud material crashes Keyshot
Started by Hellborn, February 12, 2015, 12:12:21 PM
Hellborn
Having problems with Tiled Concrete Material from cloud crashing Keyshot.
When I apply it Keyshot hangs.
how are you applying it? Just simple drag and drop?
Hellborn
#2
Yes.
Just drag and drop.
Can add that when draging and droping, normally, the area that will recive the color lights upp and get the color but nothing happend.
If I did not drop it in that case Keyshot continue to work fine.
Tried another Cloud material downloaded at another time and it worked fine.
Maybe you can test it and make sure it works.
Teoretically this can be related to another post I will make in a few minutes about running out of diskspace.
I't is possible that the material not saved to disk correctly because of low disk space and got corrupted some way.
I have to check to witch disk downloaded materials saves to.
If that's the case it's probably nothing wrong with the material as it is on the cloud, it might have gotten corrupted on download.
But if files did not fit on disk it should not be possible to download without some kind of error.
