I am in the process of trying to understand the different import methods and the benefits of each so I can effectively create a workflow.
This is the situation.
From the many tutorials about Keyshot on the the interwebs, the models that have been brought in from external 3d apps all have different materials assigned so Keyshot can tell the difference between each part so each material can be applied separately.
This I do understand.
However In Maya if you create a group for a example - wheelset and within that group there are three objects
Tire
Rim
Wheel Nuts
Keyshot seems to be able to read the FBX folder structure, so in essence I can apply a material to the Group ie - Wheelset
OR
I can apply materials to each separate object within the group ie, Tire, Rim, Wheel Nuts.
Since this seems possible, what advantage would there be - in Maya to apply for example 80 different materials to a car then to import into keyshot, If keyshot can already read the FBX folder structure.
Many Thanks
