Blending is Possible in Keyshot?
Started by sahibzada, March 12, 2015, 04:51:15 AM
sahibzada
Hi guys i m new to Keyshot, i found this application very user friendly, very light, and unbelievable result.
But i got some problem i m putting stitches on shirt(texture) but i think it is not possible in keyshot.
here the snapshot is http://prntscr.com/6ftsly
Hi sahibzada,
The stitches will either need to be modeled or put in by using a texture/bump combo. UV mapping would be way easier but modeled would look better, I believe.
Chad
sahibzada
I m posting another snapshot, this engine i found very limited i think i need to switch back to Vray :(
http://prntscr.com/6g86hk
If you UV mapped this, than it should be pretty simple. Just point to the textures and such you created and switch over to UV mapping. The procedural textures, you seem to be using, won't have the UV mapping option, obviously.  ;)
sahibzada
Not sure - haven't used that particular program. Are they that large when they are mapped? You can scale the UV mapping too, if needed.
sahibzada
evilmaul
cause you painted the stitches too big (and I am not talking about the file size) for your UV layout! Isnt it obvious?
