Author Topic: Blending is Possible in Keyshot?  (Read 4210 times)
Offline sahibzada
« on: March 12, 2015, 04:51:15 am »
Hi guys i m new to Keyshot, i found this application very user friendly, very light, and unbelievable result.
But i got some problem i m putting stitches on shirt(texture) but i think it is not possible in keyshot.
here the snapshot is http://prntscr.com/6ftsly
Offline Chad Holton
Re: Blending is Possible in Keyshot?
« Reply #1 on: March 12, 2015, 05:05:47 am »
Hi sahibzada,
The stitches will either need to be modeled or put in by using a texture/bump combo. UV mapping would be way easier but modeled would look better, I believe.
Chad
Offline sahibzada
« Reply #2 on: March 13, 2015, 04:34:00 am »
I m posting another snapshot, this engine i found very limited i think i need to switch back to Vray :(
http://prntscr.com/6g86hk
Offline Chad Holton
« Reply #3 on: March 13, 2015, 04:47:43 am »
If you UV mapped this, than it should be pretty simple. Just point to the textures and such you created and switch over to UV mapping. The procedural textures, you seem to be using, won't have the UV mapping option, obviously.  ;)
Offline sahibzada
« Reply #4 on: March 13, 2015, 05:00:02 am »
Here the Stitches one:
http://prntscr.com/6g8fe5
Unwrapped one
http://prntscr.com/6g8gki
Final One
http://prntscr.com/6g8gyc
Why the stitches are too big?
Offline Chad Holton
« Reply #5 on: March 13, 2015, 05:18:26 am »
Not sure - haven't used that particular program. Are they that large when they are mapped? You can scale the UV mapping too, if needed.
Offline sahibzada
« Reply #6 on: March 13, 2015, 05:22:42 am »
I used Photoshop, 2048x2048 Sheet.
Offline evilmaul
« Reply #7 on: March 16, 2015, 05:45:36 pm »
cause you painted the stitches too big (and I am not talking about the file size) for your UV layout! Isnt it obvious?
