Apple watch
Started by alexx, June 23, 2015, 07:42:38 PM
alexx
Line-up of the apple watch sport.
alexx
a change of scenery
The renders are #StraightOuttaKeyshot, only aspect ratio and a touch of noise added.
I'm hoping that i nailed the perspective :)
Josh3D
Perspective looks great, but the colors are a bit muted. If you're looking to match Apple product shots, you'll need to amp up the brightness.
alexx
thanks josh,
my initial plan was to make them like that dull, so in post i deliberately took down the saturation a bit :)
my worries were if the perspective was right
I think some hard highlights would really benefit these if you wanted to make them pop a bit more. Looks as if you're using the default (or similar) hdri.
alexx
Quote from: willgibbonsdesign on August 30, 2015, 05:28:49 PM
I thought about that too... maybe on the colorful (product) version, yes. it can benefit from it. As for the last two I tried many versions and lightnings. This setup best captures what i had in my mind, dull and under saturated. Nothing to pop and distract :)
thanks for the suggestion will
