Hi all!
Thank you for the Zbrush bridge - makes it so nice working between the 2 applications!
One question/request - When I send a model over to KS through the bridge I have to spend some time with the KS camera as the orientation is way off between the 2 applications. I generally work with my models in Zbrush at 0,0,0 - when they enter KS they are facing the opposite direction, as well as tilted 90 degrees. The KS floor is vertical after I get it aligned right. This is a kink in the workflow for me. I happened to notice in a tutorial video (they were using the full version I believe) that some orientation and scale settings are available when you use the import function - this doesn't appear to be available in the Zbrush bridge however. Or are they?
If not it would be a great addition to the bridge to also have these settings available.
Please move to the feature request if needed - I wasn't sure if the settings existed or not.
Thank you
Daf
