Render Directory Changes
Started by Robb63, December 03, 2010, 10:48:22 AM
Robb63
When I'm setting up renderings in Pro; I tell it to render to a certain directory, then add the renders to my que. When I open a different bip file to add it to the que the render directory has set back to the default fo rthe new bip and I have to go through the process of choosing the directory I wan again.
JeffM
Setting the render folder in the render options window will reset when KeyShot is reloaded like when you open a new bip file. That setting is only saved per session. You can, however, easily change the default setting by going to edit>preferences>folders and then setting "rendering folder" to a new folder. This will stay set as the default until you choose to change it.
I hope that works for you!
Robb63
So Keyshot counts opening a new file as if it were re-launching Keyshot and that is why it resets?
Yes, that's essentially what it does.
