Author Topic: Surface seems to incline  (Read 6141 times)
Offline Zvi
« on: March 15, 2016, 07:49:08 am »
There is a problem with the map, Somehow it seems to incline. Changing focal length didn't solve the problem. The camera is in perspective mode.
Offline Speedster
Re: Surface seems to incline
« Reply #1 on: March 15, 2016, 02:51:34 pm »
Is the map a backplate, or is it a label on a ground plane?  If the latter, it should have created the same perspective as the models.  You might want to place it on a curved backplate, flat under the models, then curving up and out of view.  Like a "cyclorama stage" in studio photography. I suspect it's a backplate, in which case you have a lot of work to do!
Offline Zvi
« Reply #2 on: March 15, 2016, 05:01:40 pm »
It's an image projected on a surface.
Offline Zvi
« Reply #3 on: March 16, 2016, 03:11:01 am »
I'm attaching the file with the map, hopefully someone will find a solution.
Offline TpwUK
« Reply #4 on: March 16, 2016, 04:48:53 am »
I took a look, the map looks better if you use UV Mapping. Why are you using meters as your units of measurement? Your scene would be better using inches or even mm. Whatever scale you modeled at should be the units you use in KeyShot
Offline Esben Oxholm
« Reply #5 on: March 16, 2016, 02:17:05 pm »
Hi Zvi
I think that taking the focal length down from 120 to something around 80 makes it look better.
Best,
Offline Zvi
« Reply #6 on: March 17, 2016, 01:37:29 am »
Hi Zvi
Best,
Hi Esben,
You are right. It looks better, but still it looks odd, although I changed the focal length to 60.  And by the way, I really enjoyed your tutorial. You are a great artist!
« Reply #7 on: March 17, 2016, 06:30:47 am »
Thanks a lot! Glad you enjoyed it. Much appreciated.
I guess it maybe looks odd because of the way Italy is shaped. It's actually getting a bit broader towards the top, but the perspective makes it look more straight... not sure. I think if the map had some parallel straight lines on it, it would look fine, but they probably didn't use that in the old days :)
Offline TpwUK
« Reply #8 on: March 17, 2016, 07:16:06 am »
Makes me wonder if the  map was a section captured/cropped from a globe if you know what i mean
