Surface seems to incline
Started by Zvi, March 15, 2016, 07:49:08 AM
Zvi
There is a problem with the map, Somehow it seems to incline. Changing focal length didn't solve the problem. The camera is in perspective mode.
Speedster
Is the map a backplate, or is it a label on a ground plane?  If the latter, it should have created the same perspective as the models.  You might want to place it on a curved backplate, flat under the models, then curving up and out of view.  Like a "cyclorama stage" in studio photography. I suspect it's a backplate, in which case you have a lot of work to do!
Zvi
Quote from: Speedster on March 15, 2016, 02:51:34 PM
It's an image projected on a surface.
Zvi
I'm attaching the file with the map, hopefully someone will find a solution.
TpwUK
I took a look, the map looks better if you use UV Mapping. Why are you using meters as your units of measurement? Your scene would be better using inches or even mm. Whatever scale you modeled at should be the units you use in KeyShot
Esben Oxholm
Hi Zvi
I think that taking the focal length down from 120 to something around 80 makes it look better.
Best,
Zvi
Quote from: Esben Oxholm on March 16, 2016, 02:17:05 PM
Hi Zvi
Best,
Hi Esben,
You are right. It looks better, but still it looks odd, although I changed the focal length to 60.  And by the way, I really enjoyed your tutorial. You are a great artist!
Esben Oxholm
Quote from: Zvi on March 17, 2016, 01:37:29 AM
Thanks a lot! Glad you enjoyed it. Much appreciated.
I guess it maybe looks odd because of the way Italy is shaped. It's actually getting a bit broader towards the top, but the perspective makes it look more straight... not sure. I think if the map had some parallel straight lines on it, it would look fine, but they probably didn't use that in the old days :)
TpwUK
Quote from: Esben Oxholm on March 17, 2016, 06:30:47 AM
Makes me wonder if the  map was a section captured/cropped from a globe if you know what i mean
