Lighting - Steps on Reflective Surfaces
Started by csdzz, March 30, 2016, 12:30:33 AM
csdzz
Hi all,
I have some troubles with stepped reflection on large plane surfaces as below:
The steps are directly visible on the Keyshot scene itself, not only on renderings (even with Tiff 32b). I tried to use a larger hdri or to use individual lights instead, it does not look better. I need to render some close-up views so it will be quite visible.
Is there any trick to solve this issue? Anyone faced the same problem? Thanks
