Author Topic: My lighting become blue, this is crazy...  (Read 6631 times)
Offline Libellso
« on: April 27, 2016, 03:47:06 am »
Hello!
I made many pictures with the same settings for lighting without any problem but suddenly, my lighting (not all of it, just a part of my picture) is become blue...
I have changed the IES Lights, I have imported my lights again, but it doesn't change anything.
And it's not the first time, I already had this problem before with an other file.
I don't have change my settings at all between two rendering.
This come from nowhere...
Someone can help me please?
Thank you in advance! :)
« Last Edit: April 27, 2016, 03:49:01 am by Libellso »
Offline Chad Holton
Re: My lighting become blue, this is crazy...
« Reply #1 on: April 27, 2016, 05:50:22 am »
Not sure what may be causing it. What version are you using exactly (e.g. 5.0.123)?
Chad
Offline Libellso
« Reply #2 on: April 27, 2016, 05:57:40 am »
Chad
Hello Chad,
I'm using the 5.0 Pro.
Offline bdesign
« Reply #3 on: April 27, 2016, 06:13:50 am »
This appears to be a reflection, not a lighting issue. You can see this blue reflecting in the frosted glass door, the edge of the glass in the foreground, and the edge of the gold metal side of the tabletop. When toggling between the two renders, the overall reflections move by a few degrees- did you rotate the environment, even slightly? Sometimes it only takes a few degrees change to make a substantial difference. Can you share the scene?
Eric
Offline Libellso
« Reply #4 on: April 27, 2016, 06:27:13 am »
[/quote]
[/quote]
Sure, can I have your e-mail adress please? The file is very heavy...
Thank you
Offline bdesign
« Reply #5 on: April 27, 2016, 06:37:06 am »
Upload it to File Dropper (filedropper.com)? Free, 5GB capacity, no registration required.
Offline Libellso
« Reply #6 on: April 27, 2016, 06:55:52 am »
Thank you in advance for your return.
« Last Edit: April 28, 2016, 08:38:17 am by Libellso »
Offline bdesign
« Reply #7 on: April 27, 2016, 09:48:38 am »
Ok, I've figured it out and...this is one of the stranger issues I've yet seen. The problem occurs with a particular material when you enable Global Illumination in this scene. The artwork model on the wall inside the room behind the frosted glass doors is emanating the bluish purple color. The plane has a Paint material applied, with a texture mapped Color. You have the Brightness value of the texture map set at 1.8, which is blowing it out, over-saturating the bounce light from Global Illumination, causing the tint. I set the Brightness value to 1, and all is good. Oddly, this only happens if the material type is set to Paint or Metallic Paint. If changed to any other material type, the tint doesn't occur, even with the higher Brightness value. Perhaps this is a bug (?). I've attached some screen shots.
Eric
« Last Edit: April 27, 2016, 06:10:52 pm by bdesign »
Offline Libellso
« Reply #8 on: April 28, 2016, 03:13:42 am »
Eric
Thank you Eric to have checked my file.
So, I changed the material and it's ok, it's really weird...
Offline bdesign
« Reply #9 on: April 28, 2016, 05:36:29 am »
You're welcome, Libellso. It is weird. I think perhaps this is a bug.
Eric
Offline Chad Holton
« Reply #10 on: April 28, 2016, 08:13:55 am »
Thanks for checking out this one, Eric. Downloading now and will report it.
Chad
Offline bdesign
« Reply #11 on: April 28, 2016, 08:28:51 am »
No problem, Chad. You're welcome.
Eric
